RadiMation Error: 536871958
No device driver is selected for the '<DEVICE-TYPE>' in the selected testsite.
RadiMation® is trying to load all the necessary devices from the selected test-site, however the test-site doesn't have a device driver selected for the specified '<DEVICE-TYPE>', while this is needed for the configured test.
Solution
- Change the configuration of the test-site, to include a device driver for the specified '<DEVICE-TYPE>'.
- If this error is unexpectedly raised for a 'Forward power meter' not being present in the testsite, this is probably caused by the forward power amplifier protection that is configured for the amplifier within the testsite. If you are sure that you want to use the amplifier without a forward power amplifier protection, the maximum forward power correction file of the amplifier should be removed.
- If this error is unexpectedly raised for a 'Reflected power meter' not being present in the testsite, this is probably caused by the reflected power amplifier protection that is configured for the amplifier within the testsite. If you are sure that you want to use the amplifier without a reflected power amplifier protection, the maximum reflected power correction file of the amplifier should be removed.
- If this error is unexpectedly raised for an ad converter please check in the eut if monitorchannels are enabled. If this is not the case check the monitor tab of the test site to see if monitoring is set up here. If both tabs are empty and you still get the error, please check in the test if a limit is used "Limit performance". Using limit performance tells the software to monitor the ad channels to see if they go under a set threshold. If this is used in the test but you are not using monitoring anymore it needs to be removed else you are not able to execute the test.
