RadiMation Error: 536871988
Forward power amplifier protection was selected, however the protection file ('<filename>') was not found. Please check the settings of your amplifier.
The configuration of the test or calibration is done to include a protection on the forward power coming out of the amplifier. RadiMation however has detected that there is a problem with the loading of the forward power limitation which is specified for the amplifier that is used in the testsite. Without the actual forward power limitation values, it is not possible to perform the forward power protection.
The filename that is being loaded is shown in the error message. It could be that the selected file is not available anymore becuase it is renamed or moved. If no '<filename>' is included in the error message, probably no file at all is selected for the forward power limitation of the amplifier device driver.
Also see: Amplifier Maximum forward power correction file and Amplifier Protection
Solution
  • Open de device driver configuration of the used amplifier, and check the filename of the file that is seleced for the forward power protection file. Check if this file is still available, and can be opened as a Correction file in RadiMation.
  • Restore the original file on the original location
  • Select another (or the renamed/moved) file as the forward power protection file in the device driver configuration of the amplifier.
  • Unselect the forward power protection in the configuration of the test of the calibration.
