RadiMation Error: 536872011
The variable test level file has no 'Power' column. A 'Power' column should be included in the file
A variable test-level for the power test-level is selected, with a corresponding correction file. However the correction file does not contain a 'Power' column.
Solution
- Select another correction file (that does have a 'power' column) for the variable test-level
- Adjust the correction file to also include a 'power' column, containing the desired power values.
