RadiMation Error: 536872020
No test specific template is specified for the test '<TEST>'. The results of this test will not be included in the report
During the report generation, the report generator has detected that a test-specific template should be included. However the test with the name <TEST>, doesn't have an associated test-specific template. For the mentioned test it is not possible to include the test-information, so the results of that specific test will thus not be included in the final report. The results for the other tests will be included in the final report (if they have an associated test-specific template).
This error code can be generated if the Test specific report generator templates functionality of the report generator is used.
Solution
- Attach a test-specific template to the mentioned test.
- Adjust the main-template to not include the test results from the mentioned test-type.
- Remove the selection mark from the mentioned test in the report generator configuration window, so the mentioned test will not be included in the final report.
