RadiMation Error: 536872037
Not all settings are correctly configured, please verify the settings and try again.
RadiMation® has performed a check on the values that are specified, and found one or more problems. The problem is also specified in the error message itself. Because of these invalid values, the data cannot be used and the data cannot be saved to a file on disk, to prevent that errors will be generated. It is important to first fix the mentioned problems, and then save the data again.
Solution
  • Change the values that are specified in the settings, as suggested by the description in the error message.
