RadiMation Error: 536872042
The 'Variable' test-level is not supported. Use a 'Constant' test-level.[edit]
When an antenna scan calibration is performed, this can be performed with the 'signal generator method' or the 'network analyser method'.
  • Signal generator method: will control the signal generator to regulate the forward power to the desired power level, and measure with the spectrum analyser on the receiving antenna.
  • Network analyser method: will only use the network analyser to generate a power level on one port, and measure the received signal on the receiving antenna with the other port.
If a network analyser is present in the selected testsite the 'Network analyser method' will be used, otherwise the 'Signal generator method' will be used.
This error indicates that a variable test-level is selected in the TSF, in combination with the 'Network analyser method'. When the 'Network analyser method' is used, it is only allowed to use the 'Constant' 'test-level'.
Solution[edit]
  • Select the 'Constant' 'Test-level'.
  • Use the 'Signal generator method', by removing the 'Network analyser' device driver from the selected testsite.
