RadiMation Error: 536879960
'<ENGINEER>' can not be removed because this is a protected engineer.
The mentioned engineer cannot be removed from the list of engineers because it is protected. This is probably because this engineer is used as the engineer that will be logged in by default when RadiMation® is started.
It is also possible that the engineer cannot be removed, because it is the currently logged in engineer.
Solution
- Change the default login engineer to another engineer, and then remove the engineer.
- Login as a different engineer, and then remove the engineer.
- Contact radimation-support@raditeq.com
