RadiMation Error: 536879969
The correction file ('<correction filename>'), does NOT contain the required column: <column-name>.
During the loading of the specified correction file, it is checked if the correction file has a specific column. This error is raised if it is detected that a column that is required is not present in the in the correction file.
Solution
  • Correct the contents of the correction file, to also include the specified '<column-name>'.
  • The 'Correction file uses' section of Chapter 14 of the manual contains a description of the expected content of the correction file.
