RadiMation Error: 536879973
The correction file ('<correction filename>'), has the required column '<column-name>', which is not the first column.
During the loading of the specified correction file, it is checked that the required column ('<column-name>') is the first column. This error is raised if it is detected that the required column is one of the later columns in the correction file.
Solution
  • Correct the contents of the correction file, by moving the specified '<column-name>' to the first column.
  • The 'Correction file uses' section of Chapter 14 of the manual contains a description of the expected content of the correction file.
