RadiMation Error: 536879974
The correction file ('<correction filename>'), has the column '<column-name>', which is not continuously increasing. This column should be sorted.
During the loading of the specified correction file, it is checked that the required column ('<column-name>') has a continuously increasing value in the column. This error is raised if it is detected that the contents of the specified column is not sorted. The values in this column should be increasing, to prevent problems and confusing.
Solution
  • Correct the contents of the correction file, by moving sorting the values in the specified '<column-name>' column.
  • The 'Correction file uses' section of Chapter 14 of the manual contains a description of the expected content of the correction file.
