RadiMation Error: 805306519
The IDN response did not contain the required segments
A check is done to retrieve information on what device is connected. This is often done by requesting the `*IDN?` of the device, and parsing the response. One of the devices connected didn't respond with an expected response that RadiMation is able to handle.
Possible solution(s)
  • Remove devices one by one until you have found the device that is causing the problem. This could also be on the local network.
    • Make sure that RadiMation supports this device.
  • If the error still appears in the latest version of the device driver: Contact your reseller, radimation-support@raditeq.com or send an Error Report to resolve this error in the device driver.
