RadiMation Error: 805306554
Could not move a device driver configuration from to the output directory
The found device driver needs to be moved to an output directory once a device driver has been found. This error happens if for whatever reason the device driver could not be moved.
Possible solution(s)
- Try starting the scan again
- Try restarting RadiMation
- Try updating the drivers
- Make sure there is enough disk space
- Make sure that "%temp%" is writable
- Make sure that the configuration directory is writable
- If the error still appears in the latest version of the device driver: Contact your reseller, radimation-support@raditeq.com or send an Error Report to resolve this error in the device driver.
