RadiMation Error: 805306574
<DEVICE>: Device not connected
During a check to verify if a device (more specifically the <DEVICE>) is connected, the presence of the device could not be verified.
Solution
- Check if the controlled device is powered on
- Check if the controlled device is connected to the communication bus
- Check manually if the device is working correctly as expected
- Check if the correct device driver is used to control the device
- Check if the correct settings for the communication bus are specified
- Check if the correct address or module address is specified
- In some cases, a device can emulate a different device. In RadiMation, the same emulated device must be selected for the device driver.
