RadiMation Error: 805308284
Warning that threshold limit of forward or reflected RF power has been exceeded
A Bonn amplifier reported that too much forward power is generated or too much reflected power is detected.
This error message is related to the internal Bonn status code: "POWCTL x WARN". Lookup in the user manual of the Bonn amplifier what the exact cause of this error is, and how it can be resolved.
Possible solution(s)
- Check the actual forward power out of the amplifier, and determine if it is indeed more than the amplifier should generate
- Check the actual reflected power going back into the amplifier, and determine if this is high. Is the difference between the forward and reflected power acceptable, or is it small?
