RadiMation Error: 805308872
Syntax is sent when an invalid command is received
The command that is send to the device, is invalid.
Solution
Possible reasons for this error can be:
- Incorrect unit is configured in the device driver. Please verify the configured Unit matches the device Unit on the controller device. E.g. Antenna tower is on Unit 1. Turn Table is on Unit 2.
If this problem remains after manually checking the above options, further investigation by Raditeq is necessary to find the real cause of this problem.
