RadiMation Error: 805309418
R&S ESU series system error
An device specific error is detected by the R&S receiver. The exact reason or cause of the error is completely depending on the device. The error description itself will also include the error message that is retrieved from the R&S receiver itself. That message is retrieved from the System error queue. Often that error description gives an indication of what is going wrong, and could give a clue on which setting should be modified to resolve the problem.
Solution
  • Use the information that is provided in the error description to determine which setting is causing this error, and modify the relevant setting to the correct value.
  • Otherwise, please report this problem to Raditeq, using the Error Report function.
