RadiMation Error: 805317369
Signal generator level is going below the minimum
The R&S Signal generator is being controlled to a signal carrier level that is below the minimum carrier level.
Solution
- Determine the exact cause why the carrier level is reduced to a value that is below the minimum.
- Increase the desired test level to a higher level, to prevent that the carrier level becomes too low.
