RadiMation Error: 805334073
Modbus is not able to read the minimum amount of bytes to contain a valid frame.
Modbus is not able to read the minimum amount of bytes to contain a valid frame message appears when data has been retrieved, a frame is found, but still not enough data (registers) are present to interpret the set data format from the received data.
Possible solution(s)
  • Does the read start register has enough register after this address to retrieve and interpret the data correctly?
  • Is the connection with the device still active and uninterrupted?
  • Try to re-connect with the device.
