RadiMation Error: 805334173
The number of frequency points is not correctly set
During the control of the Aaronia Spectran analyser, it was not possible to set the desired number of frequency points.
Solution
Possible reasons for this error can be:
  • The selected number of frequency points is outside the valid range of frequency point values of the Aaronia Spectran analyser
  • A wrong configuration of one of the emission measurement parameters. Try to change the parameters to more often used values.
If this problem remains after manually checking the above options, further investigation by Raditeq is necessary to find the real cause of this problem.
