RadiMation Error: 805334176
The sweeptime is not correctly set
During the control of the Aaronia Spectran analyser, it was not possible to set the desired sweeptime.
Solution
Possible reasons for this error can be:
  • The selected sweeptime of the emission measurement is outside the valid range of sweeptimes of the Aaronia Spectran analyser
  • A wrong configuration of one of the emission measurement parameters. Try to change the parameters to more often used values.
If this problem remains after manually checking the above options, further investigation by Raditeq is necessary to find the real cause of this problem.
