RadiMation Error: 805334180
The requested detector type is not supported[edit]
During the control of the Aaronia Spectran analyser, it was not possible to set the desired detector. The Aaronia Spectran only supports the 'PK' and 'RMS' detectors. The 'Average' and 'Quasi-Peak' detectors are not supported.
Solution[edit]
Possible reasons for this error can be:
  • Do not select the 'Average' or the 'Quasi-Peak' detector.
  • A wrong configuration of one of the emission measurement parameters. Try to change the parameters to more often used values.
If this problem remains after manually checking the above options, further investigation by Raditeq is necessary to find the real cause of this problem.
