RadiMation Error: 805355870
The RBW should be 952.381 kHz when the QP detector is used above 1 GHz.[edit]
The Quasi peak detector is used on a frequency that is higher than 1 GHz. On those frequencies the RBW should be 952.381 kHz, however that is currently not the case.
Solution[edit]
  • Use a RBW of 952.381 kHz, when Quasi peak measurements are performed on a measurement frequency of 1 GHz or higher.
