RadiMation Error: 805366371
Cannot use the preamp and attenuator at the same time
The AFJ receiver is controlled using a test configuration that has a fixed value for the attenuator and the preamplifier. This is not supported by the AFJ receiver itself.
Solution
- Only use the attenuator or the preamplifier, the device does not support both settings at the same time. The other setting should be set to Auto
