RadiMation Error: 805372576
The measured value of pressure is lower than the configured minimum environmental limit. The measured pressure is: <actual> mBar, while the allowed minimum is <minimum> mBar
The measured value of pressure is lower than the configured minimum allowed pressure.
This error indicates that the measured pressure value from the Netatmo environmental sensor is below the configured minimum pressure.
Solution
Increase the pressure of the test environment, or adjust the minimum allowed pressure in the device driver.
