RadiMation Radiated Immunity Questions
Questions Radiated Immunity:
  • Which EMC phenomen is tested/checked in RI tests?
  • Accoording to which standard is tested?
  • Where is the setup of the RI test described?
  • Is the setup different for CE/MIL-STD/Automotive?
  • Create a schematic with all the parts of the test-setup
  • Describe the reason/goal/ responsibility of all parts of the test-setup
  • How is garanteed that RadiMation applies the test-level that is specified in the standard
  • Which parts of the test equipment setup are uncertain. How does this influence the test result? How is this uncertainty solved?
  • How is checked that the EUT is influenced?
  • Which information needs to be 'stored' to generate a report.
  • How long does it take to perform RI tests on an EUT?
  • How can the total testtime be improved?
  • Which devices can be used to generate an electrical field?
  • How can it be detected if too much reflections are present in an anechoic chamber?
