RadiSwitchInternalOnlyDeviceDriverConfiguration
Note: This page is used to show the configuration of the Raditeq RadiSwitch device drivers, which only have relay that is available on the back of the plugin card itself. It doesn't provide the possibility to control an external relay box. This page can now easily be embedded on all relevant device driver pages.
The following tabs are available in the advanced configuration of the RadiSwitchInternalOnlyDeviceDriverConfiguration:
There are several methods in which the RadiSwitchInternalOnlyDeviceDriverConfiguration can be connected to the PC. The RadiSwitchInternalOnlyDeviceDriverConfiguration can for example be connected directly to the PC, or through a plugincard in a RadiCentre 1 or a multi-slot RadiCentre. More information on how to use the RadiCentre is present in the product manual of the RadiCentre. The settings on the RadiCentre tab can be used to specify how the RadiSwitchInternalOnlyDeviceDriverConfiguration is connected.
When the RadiSwitchInternalOnlyDeviceDriverConfiguration is connected to a multi-slot RadiCentre, also the slot number in which the plugincard is fitted, should be specified.
ScreenElementDescription.svg Directly to PC Specifies that the RadiSwitchInternalOnlyDeviceDriverConfiguration is connected directly to the PC, without the use of a RadiCentre.
ScreenElementDescription.svg RadiCentre 1 Specifies that the RadiSwitchInternalOnlyDeviceDriverConfiguration is connected to a plugincard that is fitted in a RadiCentre 1.
ScreenElementDescription.svg RadiCentre multi-slot Specifies that the RadiSwitchInternalOnlyDeviceDriverConfiguration is connected to a plugincard that is fitted in a multi-slot RadiCentre that also can be manually controlled using the display on the front of the RadiCentre. The slot number in which the plugin card is mounted can also be selected.
ScreenElementDescription.svg RadiCentre multi-slot Ultra Specifies that the RadiSwitchInternalOnlyDeviceDriverConfiguration is connected to a plugincard that is fitted in a multi-slot RadiCentre Ultra. This RadiCentre Ultra has no display, and can only be used when remote controlled.
The configuration on the Communication tab should be configured depending on the outgoing connection from the PC. Thus if Directly to PC is selected, the communication settings should be configured as what is actually used between the PC and the RadiSwitchInternalOnlyDeviceDriverConfiguration itself. If RadiCentre 1, RadiCentre multi-slot or RadiCentre multi-slot Ultra is selected, the communication settings should be configured as what is actually used between the PC and the RadiCentre. In the configuration where a RadiPower is connected with USB to a multi-slot RadiCentre, which is connected by GPIB to the PC, the communication settings of the RadiPower device driver should thus be GPIB.
If the RadiSwitchInternalOnlyDeviceDriverConfiguration is for example connected to slot 3 of a multi-slot RadiCentre which has IP address 192.168.178.95 and is connected by LAN to the PC, the following settings should be configured in the device driver of the RadiSwitchInternalOnlyDeviceDriverConfiguration:
  • RadiCentre tab
  • Communication tab
    • Communication Stream: VISA
    • LAN: 192.168.178.95
The Firmware update tab can be used to update the firmware of the RadiSwitchInternalOnlyDeviceDriverConfiguration.
Warning: The firmware update can take a few minutes. During the actual firmware update the window is disabled, and cannot be closed. It is possible that Microsoft Windows shows messages that the RadiMation® software is not responding. Ignore those messages and do not kill, abort or end the software. Also do not disconnect the connection between the RadiSwitchInternalOnlyDeviceDriverConfiguration and the PC, while the firmware update is being performed.
This allows that the relay switch settings can be completely different during and after the test. A possible situation is that the input of the analyser needs to be disconnected from the antenna, after the test has ended, to be sure that high voltage levels are damaging the analyser input. Another possible scenario is that the high power amplifier is switched to a dummy load, after the test has ended, to be sure there is no RF power in the anechoic chamber.
ScreenElementDescription.svg Relay A The output state that should be activated for Relay A on the switch card. It is also possible to not switch at all with the option Do not change
ScreenElementDescription.svg Relay B The output state that should be activated for Relay B on the switch card. It is also possible to not switch at all with the option Do not change
