Raditeq GTM1100A
The Raditeq GTM1100A device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Raditeq GTM1100A:
The frequency range of the Raditeq GTM1100A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Raditeq GTM1100A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Raditeq GTM1100A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Raditeq GTM1100A
- Google image search: Raditeq GTM1100A
