Raditeq RLK3086R
The Raditeq RLK3086R device driver is a Cable which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Raditeq RLK3086R:
The frequency range of the Raditeq RLK3086R as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Raditeq RLK3086R.
Be careful changing these settings as RadiMation® is no longer able to verify if the Raditeq RLK3086R is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
