Raditeq RadiField adjustment for amplifier module
The Raditeq RadiField adjustment for amplifier module device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Raditeq RadiField adjustment for amplifier module:
The frequency range of the Raditeq RadiField adjustment for amplifier module as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Raditeq RadiField adjustment for amplifier module.
Be careful changing these settings as RadiMation® is no longer able to verify if the Raditeq RadiField adjustment for amplifier module is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Raditeq RadiField adjustment for amplifier module
- Google image search: Raditeq RadiField adjustment for amplifier module
