Regular expression
A Regular expression is a text pattern that describes how textual input should be parsed to retrieve a piece (or complete) of the textual input.
For regular expression we advise, to learn on how to use regular expressions, at a dedicated internet site. For example: https://www.regular-expressions.info/tutorial.html
An online regular expression tester can also be used to verify the correctness of the regular expression: https://regex101.com/
In RadiMation® the Regular expressions are often used to interpret the response of a device. Several configurable device drivers, provide a possibility to specify the regular expression to convert the response on a query-command into a value.
The most complete regular expression to retrieve a floating point number from a response is:
The part of the regular expression that is included within the outermost brackets is taken as the final result.
Some simple examples for interpreting a response are:
| AC_FREQ;Channel1;1.23E+3 | ;.*;(-?[0-9.,Ee+-]+) | 1230 | Takes the first number after the appearance of a second ";". |
Links[edit]
- Wikipedia: Regular Expression
- Regular expression tutorial: http://www.regular-expressions.info/tutorial.html
- Regular epxression tester: https://regex101.com/
