Rigol Technologies DSG3030
The Rigol Technologies DSG3030 device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rigol Technologies DSG3030:
The frequency range of the Rigol Technologies DSG3030 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rigol Technologies DSG3030.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rigol Technologies DSG3030 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rigol Technologies DSG3030
- Google image search: Rigol Technologies DSG3030
