Robourough RRL MAC3
The Robourough RRL MAC3 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Robourough RRL MAC3:
The frequency range of the Robourough RRL MAC3 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Robourough RRL MAC3.
Be careful changing these settings as RadiMation® is no longer able to verify if the Robourough RRL MAC3 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Robourough RRL MAC3
- Google image search: Robourough RRL MAC3
