Rohde & Schwarz AFS
The Rohde & Schwarz AFS device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz AFS:
The frequency range of the Rohde & Schwarz AFS as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz AFS.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz AFS is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
