Rohde & Schwarz BBL200
The Rohde & Schwarz BBL200 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz BBL200:
The frequency range of the Rohde & Schwarz BBL200 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz BBL200.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz BBL200 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
Communication configuration[edit]
To setup the communication using VISA and ethernet use the "Visa-id" with value "TCPIP0::10.0.0.6::5025::SOCKET" Make sure to replace "10.0.0.6" with the actual IP address of the amplifier.
