Rohde & Schwarz ESCI 7 Scanning Receiver
The Rohde & Schwarz ESCI 7 Scanning Receiver device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ESCI 7 Scanning Receiver:
The frequency range of the Rohde & Schwarz ESCI 7 Scanning Receiver as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz ESCI 7 Scanning Receiver.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz ESCI 7 Scanning Receiver is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz ESCI 7 Scanning Receiver
- Google image search: Rohde & Schwarz ESCI 7 Scanning Receiver
