Rohde & Schwarz ESCS 30
The Rohde & Schwarz ESCS 30 device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ESCS 30:
The frequency range of the Rohde & Schwarz ESCS 30 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz ESCS 30.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz ESCS 30 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
Documentation[edit]
- The user manual can be found here
Usage[edit]
The Rohde & Schwarz ESCS and Rohde & Schwarz ESHS receivers include a 'CISPR Bandwidths' (special) function. When this CISPR Bandwidths function is selected (turned on) The receiver itself defines which RBW values to use (based on the measured frequency). In that situation the RadiMation software cannot change the RBW values. So to allow that the end-user is able to select other RBW values in the RadiMation software, the CISPR Bandwidth selection should be turned OFF!!!
From RadiMation version 4.2.1 and higher we don't send the command to turn on or turn off this special function anymore. This means that the end-user can decide which option should be used, and he will be able to (special) function from the key-panel of the receiver. The RadiMation device driver will not change the setting of this 'CISPR Bandwidths' (special) function anymore.
The CISPR Bandwidth selection can be activated by turning on 'special function number 1'.
So to conclude:
- If special function number 1 is activated in the R&S ESHS/ESCS, the receiver itself will determine the to be used RBW (based on the measured frequency). Even if the software sets a desired RBW filter, the receiver will overrule it!
- If special function number 1 is NOT activated, the selected RBW in RadiMation will be used for the RBW during the measurement.
- RadiMation does not activate/deactivate the special function number 1 option, so the end-user himself can determine which method they want to use.
