Rohde & Schwarz ESH3 (Zamm Sh.Ro.S1 Gain)
The Rohde & Schwarz ESH3 (Zamm Sh.Ro.S1 Gain) device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ESH3 (Zamm Sh.Ro.S1 Gain):
The frequency range of the Rohde & Schwarz ESH3 (Zamm Sh.Ro.S1 Gain) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz ESH3 (Zamm Sh.Ro.S1 Gain).
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz ESH3 (Zamm Sh.Ro.S1 Gain) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz ESH3 (Zamm Sh.Ro.S1 Gain)
- Google image search: Rohde & Schwarz ESH3 (Zamm Sh.Ro.S1 Gain)
