Rohde & Schwarz ESPC (Option B2)
The Rohde & Schwarz ESPC (Option B2) device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ESPC (Option B2):
The frequency range of the Rohde & Schwarz ESPC (Option B2) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz ESPC (Option B2).
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz ESPC (Option B2) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz ESPC (Option B2)
- Google image search: Rohde & Schwarz ESPC (Option B2)
