Rohde & Schwarz ESU 26 Input 2 Time Domain
The Rohde & Schwarz ESU 26 Input 2 Time Domain device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ESU 26 Input 2 Time Domain:
The frequency range of the Rohde & Schwarz ESU 26 Input 2 Time Domain as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz ESU 26 Input 2 Time Domain.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz ESU 26 Input 2 Time Domain is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz ESU 26 Input 2 Time Domain
- Google image search: Rohde & Schwarz ESU 26 Input 2 Time Domain
