Rohde & Schwarz EZ 10
The Rohde & Schwarz EZ 10 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz EZ 10:
The frequency range of the Rohde & Schwarz EZ 10 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz EZ 10.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz EZ 10 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz EZ 10
- Google image search: Rohde & Schwarz EZ 10
The Rohde & Schwarz EZ 10 manual can be found here
