Rohde & Schwarz FSEK 30 Input 1
The Rohde & Schwarz FSEK 30 Input 1 device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz FSEK 30 Input 1:
The frequency range of the Rohde & Schwarz FSEK 30 Input 1 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz FSEK 30 Input 1.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz FSEK 30 Input 1 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
