Rohde & Schwarz FSET 22 (Single Box)
The Rohde & Schwarz FSET 22 (Single Box) device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz FSET 22 (Single Box):
The frequency range of the Rohde & Schwarz FSET 22 (Single Box) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz FSET 22 (Single Box).
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz FSET 22 (Single Box) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz FSET 22 (Single Box)
- Google image search: Rohde & Schwarz FSET 22 (Single Box)
