Rohde & Schwarz FSET 7 (Double Box)
The Rohde & Schwarz FSET 7 (Double Box) device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz FSET 7 (Double Box):
The frequency range of the Rohde & Schwarz FSET 7 (Double Box) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz FSET 7 (Double Box).
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz FSET 7 (Double Box) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz FSET 7 (Double Box)
- Google image search: Rohde & Schwarz FSET 7 (Double Box)
