Rohde & Schwarz FSH 8 (model 08 and 18)
The Rohde & Schwarz FSH 8 (model 08 and 18) device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz FSH 8 (model 08 and 18):
ScreenElementDescription.svg Measure The minimum amount of measurements in the measure loop. Continues to loop even if field strength level is stable.
ScreenElementDescription.svg Max. Difference If the measured field strength between each measurement in the measurement-loop, is less than this value. The measured field strength is stable. The measurement-loop will then stop.
The frequency range of the Rohde & Schwarz FSH 8 (model 08 and 18) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz FSH 8 (model 08 and 18).
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz FSH 8 (model 08 and 18) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
