The Rohde & Schwarz FSU 3 device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz FSU 3:
The frequency range of the Rohde & Schwarz FSU 3 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz FSU 3.
Use default start frequency
Custom start frequency
Use default stop frequency
Custom stop frequency
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz FSU 3 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
