Rohde & Schwarz FSW 13
The Rohde & Schwarz FSW 13 device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz FSW 13:
The frequency range of the Rohde & Schwarz FSW 13 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz FSW 13.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz FSW 13 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz FSW 13
- Google image search: Rohde & Schwarz FSW 13
