Rohde & Schwarz HE 525
The Rohde & Schwarz HE 525 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz HE 525:
The frequency range of the Rohde & Schwarz HE 525 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz HE 525.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz HE 525 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz HE 525
- Google image search: Rohde & Schwarz HE 525
