Rohde & Schwarz HF 907
The Rohde & Schwarz HF 907 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz HF 907:
The frequency range of the Rohde & Schwarz HF 907 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz HF 907.
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz HF 907 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Rohde & Schwarz HF 907
- Google image search: Rohde & Schwarz HF 907
