Rohde & Schwarz HL 040
The Rohde & Schwarz HL 040 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz HL 040:
The frequency range of the Rohde & Schwarz HL 040 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz HL 040.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz HL 040 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz HL 040
- Google image search: Rohde & Schwarz HL 040
