Rohde & Schwarz HL 050
The Rohde & Schwarz HL 050 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz HL 050:
The frequency range of the Rohde & Schwarz HL 050 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz HL 050.
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz HL 050 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Rohde & Schwarz HL 050
- Google image search: Rohde & Schwarz HL 050
